Bro, can you please suggest 16 Pro Max wired charger watt for better battery health. I am not fan of fast charging.
Hi bro, 20W is sweet spot to use with any iPhone model. but 16 series supports upto 45W input power. you can use higher watt chargers if you want the iPhone to charge faster. else 20W will be good idea for moderate speed and optimised charging feature will take care of the charging speed. dont worry about any issues.
Just following the charging practice suggested in our video helps to maintain over period of months to reach that 2.5 years average lifetime.
Bro, i am using 15w ambrane wireless charger - is it good
Yes bro. its good. a friend of mine using it at times and so far no issues. on amazon I read about some users reporting heating issues. but my friend didnt notice such issues. warm temperature during fast charging is normal with any wireless chargers. other than that, no issues.
Thank You, Bro
