I am looking for a USB flash drive to store some of my documents from my iPhone. So that it can be accessed from different devices office and personal (windows/android/iPhone). Please suggest a good USB flash drive.
Spec:
Storage - 64 GB
Supports Type C to use in iPhone 15
version 3.2 or higher
Hi bro, you may consider any branded USB C pen drives to use with iPhone 15 model. Sandisk is normally I prefer. But for most important and sensitive data, its not safe to consider movable storage drives always.
Consider uploading them to your iCloud Drive or Google Drive account in a folder to make sure there is always a backup. then you can use pen drives to move data to local computer or other purposes.
