Hi @iRobinPro and everyone,
Hope you are doing good. How good is Airpods Pro for activities like outdoor cycling or Gym workouts… And also kindly suggest good Bluetooth tws or neckband which works very well with iPhone . My primary usage this would be for cycling and gym activities. Please share your suggestions
Hello Bro, I am good and thank you. Airpods pro is perfect fit for workouts and gym activities. If it fits your budget and you need something that fit into the apple eco system while using iPhone or other apple products. It should be suitable.
for any In-Ear type headphones, selecting the right fitting ear bud is necessary. Apple does provide different size earbuds in the case itself.
So that shouldnt be a problem and cyclists are using it already. I am using it at gym at times. Not regularly as I want the air circulation to be comfortable most of the time. But I am seeing people around me using airpods pro or airpods all the time while working out.
If you need some neckband type, then consider JBL or Sony brand also good idea based on user reviews.
