Hi Bro
Can you suggest safest brands of SD card reader or flash drive with Lightning port for iPhone 14. I need to copy files back and forth from PC to iPhone.
Thanks.
Hi Bro
Thanks.
hi bro, for iPhones with lightning port we have very less options when it comes to sd card reader. even with apple original adapters we dont have sd card reader setup for lightning port device.
you may use pen drives and sd card readers only with computers to transfer data. but for flash drive you can use the recently suggested kanget adapters. they are so far good.
Kanget Lightning to USB A OTG Adapter:
