Hii bro
Hope you’re doing good
I’m using iPhone 13 since one year and my warranty got over before 15 days and I’m having issues with my synchronised vibration which is in default, and I am unable to get the particular vibration according to the ringtone. I’m setting in the iPhone settings, so can you suggest some, solution to get my synchronised default vibration, kindly
Thank you
