Tamil Keyboard Voice command for iPhone
Sir, any voice command Tamil keyboard options available similar to English voice command keyboard? If yes, how to download?
Hi bro, if you are asking about Tamil Voice Typing on iPhone, we can use gboard. Apple voice recognition feature not yet added with the Tamil Language.
Let me know if it helps.
Thanks Sir, very useful. It’s not working. I am uninstalling and reinstalling Gboard. Will follow the steps suggested by you. Thanks again. Regards
welcome bro. sure do try that and let me know if there is any issue. gboard app receives very less update from google. I hope they update this app frequently fixing bugs.
Morning Sir. I restarted my iPhone after uninstalling Gboard. After restarting the phone, I downloaded Gboard app, and the Tamil voice typing is working now. Thanks for the guidance and help.
