Hi robin bro 15 pro max thunderbolt 4 usc c cable use panaalama bro, thunderbolt cable use pana mobile overa heat aguma vara eduvum issue vara change iruka , thunderbold type c male port hard irukama ila apple 2.0 cable madri than soft irukuma port bro US la relation vangidu varan sonaga before buying ungalta kadudu decide panalam wait panran bro plz reply
hello bro, use pannalaamnga. cable naala heat aagathunga as its branded or original cable. fast charging appo heat aagumnga. that will be managed and speed of charging will be reduce according to the temperature. just phone kaaga mattum thunderbolt 4 cable vendaamnga. namma normal amazon bascis usb c cable or belkin usb c cable itself enough to charge iPhone with full speed bro.
Data transfer namma macbook la irunthu pannurathuku intha cable use pannalaamnga. for multipurpose usage. according to your needs decide pannunga bro.
else vera accessories car or desk ku thevaipadurathu try pannunga if something have to be purchased.
macbook use panalam parthen other brand romba price sonaga bro idu vandama bro
Intha cable sollureengala?
or Thunderbolt 4 Pro cable bro?
https://www.apple.com/in/shop/product/MN713ZM/A/thunderbolt-4-usb‑c-pro-cable-18m
Thunderbolt 4 1m pro cable 6900rs
https://www.apple.com/in/shop/product/MU883ZM/A/thunderbolt-4-usb‑c-pro-cable-1m
1m thunderbolt 4 pro cable 6900rs bro idudan katan use pana vara eduvum port complint or heat agura madri issue varuma mac la conect pani data transfer panumpodu varuma illa normal nama use panra cable madri irukuma
bro inda cable data transfer in mac and sometimes charging wortha bro illa normal cable vangikalama bro before buying ungalda katkuran na yapo apple product vangata oru idea katapn bro so only asking
Fast charging appo mattum heating irukumgna. other times I havent noticed any heat complaints from people using thunderbolt cable bro. normal cable pothumnga. but if you want to transfer any Log Files or video files in bigger size to mac at 40GB/second speed support, then this cable will help.
for normal cable I think we get 10GB/ sec which is more than enough for normal users who regularly shoot and transfer videos.
Bro apple tecnical support call panan bro ungaluku message panrathuku munnadi apple thunderbolt 4 pro cable is not tested with 15 pro max its compatible but not apple recomended to use solrangala bro appo apple thunderbolt 4 cable 15 pro max use pana koodatha ida tharinjuka katkuran bro avanga solrathu 100w irukuranala adigama heat agum while charging and data transfer while using mac idu unmaya bro apa yaduku apple 10gbps support solanum avanga thara cable 2.0 its support 480 mbps thana bro
apple website la compatibility section la iPhone 15 models include pannirukaanga bro. mainly to power up and give high res output to thunderbolt display. input power iPhone side la still limit aagumnga. cable is important too. but romba confuse pannika vendaamnga. as I said before, data transfer and power input fulla iruka any normal branded usb c cable pothumnga for iPhone 15 models.
60W support pannura mathiri Belkin cable or even apple original cables are good too bro.
File transfer rate athigama irukarathaala log file mathiri recording move pannureenga na temporary heat notice pannuveenga. then auto cool down aagumnga.
Thank u bro
