Transfer of sms from andriod to iphone 14pro max
Hi Bro,
Iam using 14pro max for past 1 year. Previously i used andriod at the time of purchase i tried to transfer msg and other datas to my iphone by using move to ios app but it didnt worked and started using the ios. Will it be possible to move now all the msg from andiod to iphone. If use help me out how to do as my andriod phone is not working properly so i want to move it
Hello bro, Right now its not possible to move and merge SMS messages from android to iPhone bro. We should have tried few more times to do the transfer before starting to use the device. Else we have to format and fresh start now to do the transfer.
Even with paid apps, if we use Wondershare tool then its possible to move WhatsApp type of app specific messages, but it wont append messages to our iPhone. It still formats due to different version, encryption changes and so on.
So its not possible to move those SMS messages now bro.
You have important messages gathered all these days in your iPhone as you are using it correct?
No Bro. I have msg only from the day when i started using iphone. If i reset my iphone do i get all the apps, whatsapp msg etc will get restored. If yes plz guide me the procedure to back up my whole phone and restore once i transfer the msg from android
We cannot do two transfers or restore bro. Once you format your iPhone and restore messages from android, only android content will stay. all your iPhone backup or old data is gone.
If we restore it from iTunes backup, then android messages will be gone.
So we have to choose any one option bro.
