Truecaller Not Enabled, How to Fix?
Hi robin bro
Hope you are doing good
When I try to update the truecaller with ios 18 and true caller 14 truecaller part 1 and part 2 are not getting updated. I have true caller premium. Can you guide on this ?
BR
I am good bro. thank you. sometime truecaller servers may not be available bro. its automatically fixed. simply restart iPhone once and continue using it. the toggles will turn to green after few hours when their services are back online.
Thanks bro for your prompt response. The screenshot status is the same since yesterday evening. Any idea how to resolve this?
Hi robin bro
You are correct. The app has automatically refreshed and now it is updated. Hopefully it should work fine going forward. Thanks again for your support and help
BR
Welcome bro. no problem. Have a good day.
