Hi @iRobinPro, hope you’re doing good!
Bro, you know that I recently purchased a MacBook Air M1, and I was looking for a USB-C hub that contained only USB-A ports, but I saw a hub from Amazon Basics that was priced at ₹999, and it contains an HDMI port, a Type-C port, and a USB-A 3.0 port. So can you tell me if that is a good one, or should I buy any other hubs?
https://www.amazon.in/dp/B0BR3G9Y5V
All good bro. thank you. You may check Amazon basics hub ofcourse. recently I reviewed PiBox. you may check that too.
https://amzn.to/3q84lqK
@iRobinPro bro my battery cycle count is 3, what is mean by battery cycle count?
Each time we charge the cells inside battery and complete one full charge, it is noted as Charge Cycle Count bro. Lithium batteries calculate that cycle count and over the period, when we use it will increase. Macbooks have the cycle count upto 1000 to reach its limit. then we change battery at apple service center.
@iRobinPro bro you need to fix this website
Users are able to use HTML tags while creating posts, like
<img>, which is used to set images, but some tags like
button aren’t necessary. I know that this website uses markdown stuff, so if you’re the developer, fix it soon or tell your developer to fix this, bro.
Thanks for letting me know bro. I had to enable this feature to allow Google Ads. Let me see other work arounds to fix this.
