I am using MacBook Air M3 and iPad 6th Generation. I enabled all settings but the universal control is not working.
hi bro, iPadOS updated to latest version? both devices connected in same wifi network?
Yes bro. Both connected to same WiFi. iPad OS version 17.7.3. MacOS sequoia 15.2.
normally a simple restart of the device will help fiixng any minor bugs in this case bro. normal continuity and hand off features are working? like you are able to copy a text in iPad or Mac and paste the same on other device?
