Hi bro, currently using 15 plus and running ios 17.7.2 can i update to 18.2.1 is there any problem regarding that or any bugs? Can i update your suggestions pls!!
hi bro, 15 models are almost like new ones. my friend who bought my 15 plus updated to latest iOS 18.2 and havent faced any much issues. so far working good. you may update if you are ready to experience iOS 18 features bro. just take backup of important data before doing the update. that may help.
Can you suggest what are the important data to backup!! Pls
Photos, Videos and WhatsApp data normally bro. just taking icloud backup if you already using icloud paid storage or itunes backup if you have computer bro.
Mostly update will go smooth, but just incase as a safety measure we do such backup when we update skipping few updates.
you may update if you have good speed wifi otherwise bro.
Bro am using 15 plus can I update to latest update 18 from ios 17 is there any problem
Also in ipad 9th generation also can I update to iso 18 from 17
Bro is there any issue on 15 plus on ios 18.3 can I stay on ios 17 or can I update to ios 18.3
so far no issues reported on 15 plus model bro. if you are ready to experience iOS 18 features, you may proceed with the update. shouldnt be a problem.
Updated bro 18.3.1
ok bro. its so far stable and better. continue using it.
