Hi Robin
Is it worth Upgrading from 12 pro max to 16 plus ?
hi bro, yes it will be good upgrade from 12 pro max to 16 plus. both are 60hz display but 16 plus have brighter display overall. USB C, Dynamic Island and Improved camera system are plus sides of 16 plus model. also without spending much you can upgrade this year and make sure to get best offers.
Thanks a lot for your prompt response and valuable answer bro:+1:![]()
Currently I’m charging 4 times to 80% every day to keep using 12 pro max for daily use &
Battery drain is too much past 1 month
Overall battery percentage 89%
Can you suggest some answer ?
Welcome bro. battery must have exhausted completely. it may show higher percentage but checking with diagnostics tool at service center reveals actual battery health bro.
So in this case if you are thinking about upgrading its a good idea.
Thanks a lot bro
I ll check at service centre
Hi Robin bro,
I upgraded to 16 plus by exchange from 12 pro max battery exhausted
Now the issue is I copied all photos from 12 to windows laptop using SD Card
But photos are unable to open ,
Please suggest some app to download in windows laptop
hello bro, you can use HEIC viewer in microsoft appstore and then all those HEIC or HEVC files will be viewable.
Search for any free app and user reviews then download it bro.
Thanks bro
