Bro iphone 13 pro max 37k ku worth ah with battery health of 83% with 256 gb storage
hi bro, for 13 pro max model 256gb storage price seems reasonable. after 4 to 5 months usage you may have to replace battery at cost of 11900 price at apple serivce center if you prefer original battery. if thats ok you may consider it bro. else go with 14 series model with average of 86% battery health.
Compare the price difference of the 13 pro max and 14 pro max model and decide accordingly bro. calculate battery replacement cost also and that will be good.
