Using Belkin 37W Adapter affect iPhone Battery Health?
Will it cause any problems if I use Belkin 37W Dual Port Fast Car Charger, USB Type C 25W PPS Port and USB A 12W for iPhone 14 pro max?
no problem bro. any branded adapters can be used. use it with original or mfi cable. that should be good.
Thank you bro.
