VoLte option is not working on iPhone 13 with Jio sim. Why? With Airtel it’s working fine.
Also, if i put that jio sim on android phone VoLte is working
hi bro, do perform “Settings - general - reset - reset network settings” once. If same problem repeats, then try putting airtel or friends jio sim card to check whether the problem is happening SIM Specific or for any sim card you are seeing same error on your iPhone.
Let me know if still problem continues bro.
Thanks for your reply bro. I am using dual dim, airtel esim, jio physical sim. On airtel settings i can see Volte. But not on jio. Only LTE option for jio settings.
If you are using old jio sim like 2+ years older SIM card consider changing it at jio store bro. if its new SIM card, then do contact jio support. iPhone 13 does support 5G very well and it must be issue related to SIM or network in your area temporarily experiencing issue.
Okay bro. Will try and let you know. Thanks
