Volume Control in control center doesn’t work
Despite trying many times after 26.4 update, I have recently started to notice that when I change the volume level via control centre, it doesn’t reflect the actual volume either in speaker or on AirPods. Volume buttons work fine.
hi bro, apple released 26.4.1 with bug fixes. do update once and check. if the issue is software level we could see the fix. after update restart once and check bro.
Worked after update bro. Not sure if it’s because of the update or the restart.
Possibly a bug bro. good to know its fixed. usually a simple restart fixes this type of problems.
This bug is still present in 26.4.1, at least for me. iPhone 17 Pro
Do try restarting iPhone once and check bro. could be temporary bug too.
