Hi guys! Today morning I can see my charging
crossed 85 even I fixed it up to 85. And it went to 93 I turned off the charger and restarted, then I can see my battery charged upto 97. Why is it happening ?
Hi bro, based on our previous usage charging level could cross the set limit occasionally. It wont happen frequently, but the set limit will be bypassed as per apple document. its not a problem you can continue using it, and will notice difference in upcoming weeks.
Thank you bro !
Hi bro, but why after restart it went to 97 from 93? , this issue happened to me also recently where I charged till 84 and I restarted it showed 88 when phone turned on
Recently after ios 18.5 battery drains quickly bro is there any reason?
When we restart software level battery measurement takes sometime to show correct data bro. you can continue using it and you will see difference after few minutes.
iPhone model and current battery health percentage?
Also you can create separate post next time to handle questions separately bro.
