Bro what is qi Certified charger… and it is okay to charge iphone 14 series with this charger…
And also please let me know that how many minutes it took to charge iphone 14plus to charge above 90% with 15w wireless charging…
And also please tell bro it will heat the iPhone or not as compared to 20w wired charger
For long term better battery health can which is better 20w wired or 15w wireless?
Please best qi Certified charger for iPhone 14plue
Qi is a standard, bro. All wireless charging accessories manufacturers follow to provide one standard architecture-compatible charger.
It’s impossible to measure the exact time duration of charging as it changes between each device and based on individuals’ usage. iPhone learns and optimizes the charging speed, whether wired or wireless, based on heating if such happens during fast charging. You may get 15W or 20W wireless chargers.
Wireless charging produces heat, but it is automatically adjusted and controlled by the system. It won’t too much heat up the iPhone.
You can use anyone 15W or 20W as per your requirement.
You may consider Raegr,
https://amzn.to/3Iz9Ohh
Amkette
https://amzn.to/3GSzpAt
Or other branded wireless chargers. It will be safe. Do check Amazon Basics wireless charger too. They recently launched.
You must choose one based on the charger’s design and placement at your desk or car.
