Hi brother
Im planning to buy an iPhone 16 pro max
Enkitta etkanave apple 20w dock irukku atha use panlaama or more then 20w power
and innoru 20w dock vaangalam ndu irukren (cheap price) for my 12pro
so apple illama vera enna chargers nallam ndu sollunga please
Please advise
TIA
Hi bro, existing 20W use pannalamnga. 16 models support 45W wired chargers power inputs, but 20W is like sweet spot. you can use it if the charging duration is good for your usage case.
30 or 40W Belkin adapter mathiri kooda consider pannalaamnga if you want something higher watt to use with 16 pro max.
Third party Charging adapter like Anker 20W adapter are good to consider. normally with offer price 500 Price range la irukumnga amazon la. do check that too bro.
https://amzn.to/42TF1FM
Ugreen, Anker are good choice too bro. just check user reviews once and then buy it bro. amazon qatar site check pannitu then decide pannunga for exact product model.
