What would happen if I accidentally charge my MacBook overnight?
Good morning bro,
actually I accidentally charged my MacBook pro overnight yesterday. So will there be any problem I will be facing with my battery. Because since I got my laptop from two months, I was continuing my charging practice of 30 percentage to 85 percentage so I forgot disconnecting my charger from my MacBook Pro yesterday night it has been charged overnight and so will it occur any problem to my Mac or the battery? Kindly give your suggestion bro.
Thank you
Good noon bro. No problem in that. it automatically cut off when charging reaches 100%. so you can follow same charging practice as iPhone I have suggested in our channel. It should be good.
Okay broo thank you
