WhatsApp auto close problem in iPhone
I’m facing an issue with Whatsapp for last few days. Whenever I open the app it closes immediately. It works only after few retry. I’m currently using iPhone 13 running on ios17. Is it an issue with WhatsApp or ios17? Did anyone reported about this issue?
Hi bro, few days before one user reported similar issue. did it happen after recent whatsapp update? is your iPhone storage have enough free storage?
I updated both ios and whatsapp. So i dont know which causes the issue. Yes i have 60gb free storage. Also one of my friend reported the same issue. He too dont know what the issue is since he updated both whatsapp and ios as well.
Whatsapp bugs are getting more strange these days. I tried several troubleshooting steps and finally iOS Restore and then backup restore of whatsapp kind of fixed the problem for other audiences bro. I started suggesting users to not keep important data inside whatsapp and to take it outside if possible.
Before doing iOS Restore try to moderate the overall storage of photos, videos and other static data in your iPhone.
Then you can take backup of full iPhone and perform the restore via iTunes bro.
Then Restore the backup taken earlier and check whatsapp is working or not. Let me know if that helps bro.
