Hlo bro, whatsapp app is more background activity battery draining how to fix it ??? pls tell
Check settings - general - background app refresh and turn it off for whatsapp bro. this will restrict whatsapp from using background resources. that will help.
Background app refresh off panniyum battery activity 62% katuthu bro how to fix it???
Same problem bro
Similar issue reported by one more user bro. can you share the last 24 hours battery page screenshot with apps section visible. tap on whatsapp and then take a screenshot then share it here bro. just one screenshot is enough.
Hi Robin bro I am facing the same problem, attached the screenshot for 10 days , I have turned off the background refresh for WhatsApp
Kindly select last 24 hours graph and share it bro.
Hi bro here is the 24 hr battery stats , For some reason I feel battery backup is better after the 18.2.1 , May be just a coincidence on a single day
Got it bro. overall battery graph also looks stable. Continue with the charging practice bro it will help over time.
