recently i am facing this on my iphone 15plus that too after ios 18.3 update. my whatsapp is crashing/closing while in use i restarted and reinstalled still the issue is same can u tell me the solution for this
hi, is the whatsapp data backed up to iCloud? is the problem happening after reinstalling whatsapp fresh without any data?
do you use whatsapp regular and business version?
No my whatsapp haven’t backup to icloud and I reinstalled also still same problem im facing im using regular version whatspp.
Reinstalling whatsapp should fix the problem bro. otherwise we should go with iOS Restore once. take backup of current iPhone to Apple Devices app if you are using windows computer. then restore iOS. then restore backup of your data bro. this will fix the problem.
If the iPhone is under warranty, you can get it done at apple service center too.
Okay bro thank you. And i saw a video of urs English Channel daily tut, there u mention change to business whatsapp and again bringing back to normal whatsapp is that really works bro. I haven’t tried yet if yes i wil try. Will that lose my whatsapp data
That is possible bro. that method actually worked for me as I was not using business version and only regular whatsapp. so it should work too.
have you seen our tamil channel or just followed english one?
Im following both the channels regularly. Ok bro thank u soo much i will try that method. If solved thanks in advance
