hello bro, can you try once with whatsapp regular version? do you have 2 whatsapp installed on your iPhone?
Yes bro I have tow WhatsApp. one is regular another one is business whatsapp. what I do bro?
Whatsapp didnt enable to use screen sharing feature in Business app bro. only with regular version we can use it right now. may be in upcoming updates they will add it to business app.
Okay bro.
but i open screen share for regular whatsapp. Athula tha bro open aaha mattikku.
The error shows whatsapp business has stopped due to… bro. can you check once agian whether its whatsapp regular or whatsapp business version. I just checked with my iPhone whatsapp regular version and its working fine bro.
Okay bro again I trying
Start a video > Slide down control panel> press and hold screen recorder> select WhatsApp… that’s it…
