Whatsapp video call not working
If anyone video calls me on whatsapp i can able to attend it but my camera is blocked and also their camera is blocked the only way to fix it i need to end that call and when i started video call im able to see them ans well as my camera is also on. Please tell me to fizx this issue
Running latest iOS and whatsapp bro? when you disconnect and call again does the video option works or again same issue continues?
Im using latest ios ad wa bro i need to cut the call and from my phone i need to call them through vc . Only then it is working
This is new bro. I have tried a video call and its working well for me. can you try performing “settings - general - reset - reset location and privacy settings” once. then when you open whatsapp for the first time it asks permissions. enable them and also check permissions to microphone and camera also given.
Then try making a video call and see bro.
Bro i have Checked only to that specific person im getting this problem
Issue could be related to the other end person running older version of whatsapp may be bro. ask your friend to check that and update if needed. then try calling the same person.
Ok bro
