When is M2 Ultra Mac Studio release?
Intha Month Mac Studio Buy Pannalam nu Irukan for Video Editing Any Suggestion
Its good choice bro. M1 Max itself sufficient for most of video editing works. Only if you have no problem with budget and want to get the best one, then you may choose M1 Ultra Processor.
Also getting SSD Storage based on the footage you will keep backup and work also recommended. 1TB if needed.
Let me know if you have any further question.
Bro Mac Studio M1 Max 1TB Not Available in Chennai Stores
Only Pre Orders
Vera Vazhi illaya…???
Yes bro. If the stock is not available or if its custom model, then we have to order it only from apple india website.
