I am planing to upgrade my iphone 11 to latest, so which option i can choose, Like choosing 16 Pro max or go for 17 pro max series, bocz in all social media they are giving more cons about 17 series like color issue, network issue etc, so please suggest me
hi bro, first based on current offers and budget you can decide too. 16 pro max is still an excellent device. 17 base model is best buy value for money this year. 17 pro max needs bit more care with being the premium flagship and the possibility of damages will always be there any any aluminium frame. so wearing proper case helps that too.
Its about budget and what features you need most. 16 pro max with titanium frame and body also good choice if you need that premium feel and ok with the features it comes up with.
I am checking with couple of my friends at times whether they are noticing any color issues, and so far its good. no such changes noticed. one is using without case and another friend is using it with case. all good for now. And we cannot believe everything that comes in social media as you know, negative content goes viral easily.
So decide based on above factors and going with 16 pro max is smart and good choice budget and features wise overall too.
Just experience the 17 pro max once personally at showroom and make the decision bro.
