Which Adapter I can use for iPhone 16 Pro max?
Hai bro am newly bought iphone 16 pro max .which adaptor am used 20 or 35 watt
hi bro, both 20W and 35W are good to use. 20W is best always. gives decent speed of charging and only if you have 35W and need that fast charging support you can use it. else consider 20W if timing to charge the device is ok for you.
Thank you bro
