Which iPad is Better? 11 inch or 13 inch and Storage?
Brother , I’m a doctor and I need ipad for note taking and studying , I’m considering iPad air as my choice , now please guide me on storage and size (13 or 11)
Regarding storage 128 or 256 .
Hi bro, for studies iPad Air is very well sufficient. 11 inch model is perfect to hold and reading it. only if you want to keep it at desk most of the time then you may consider 13 inch model bro.
Getting a higher storage model is good if you plan to store more files locally. PDFs, videos and other files.
So 256GB Storage will be good choice. only for budget reasons you may consider 128GB otherwise 256GB will be safe choice.
Do experience iPad Air at showroom once. that is very important so you can personally hold and see how the handling wise iPad air feels before making the purchase. Let me know if you have any further questions.
