I Have plan to go for new 15 model but I’m not sure this change is good or not i need your suggestion, I’m general user for iphone. at present i have iphone 13 256GB.
If 13 battery and performance is suitable for your every day usage, then considering 15 model itself is good. if you need bigger display and battery then 15 plus will be good buy. My suggestion is to consider checking once at apple showroom. experience both model and see which one you can comfortably use bro. then decide accordingly.
Thanks for your feedback! I’ll go and check showroom once it’s available.
