Ipo MCA join paniruken bro
Macbook air or macbook pro which will suit best for
Like athula AI, machine learning, advanced web development , android application development,
colud computing , Iot java python inu naraya iruku bro ethu suit aagu nu doubt ah iruku clg la keten
Remdume nalla tha irukunu solranga
Congrats bro. All the best for your studies. for AI and machine learning related works based on how much data you are going to handle locally, the resource requirement will be higher bro. Initial la light usage irukumnga, but do check with your professor or seniors once. about the system requirement you will need next year or two.
for all programming tasks Macbook Pro M3 Processor with 512GB SSD and 16GB RAM will be basic requirement bro.
But RAM requirement mattum once college la check pannunga. local data processing and resource requirement poruthu thaan decide pannanum bro. above said macbook pro spec is basic and good for most above average tasks too.
