Bro icloud laa device backup nu option la backup edutha full iphone data thaane bro backup aagum including whatsapp backup and photos and videos and contacts…
if naa 200gb icloud vaangitean and ios restore muduchutu again antha data aa restore panna aparam aa antha icloud aa cancel pannikalaam la bro?
And again pudhusa phone la apple id aa login panna aparam aa verification code enter panna solli message varum aa bro apdi vantha epdi phone illaama code aa apply panna mudiyum…
and cloud buy panni full backup edukava illa finder use pannaratha bro unga suggestion enna bro …i dont want to loose any of my album of photos and video and contacts and whatsapp backup.
so unga suggestion enna bro ethula backup edukurathu and supporse phone aa setup panrapa ethuvum code vantha enna pandrathu…mobile number ku code varum nu sollraanga but i used esim in my phone so vera phone laa sim aayum poda mudiyaathu…
bro apple id aa normal aa vera phone la gmail aa login panna code varum aa bro gmail laa antha apple id oodathu
Yes bro. it takes full iPhone backup including everything. 1 or 2 months nu temporary ya icloud purchase pannitu use pannalaamnga. you can stop renewing after restoring the backup.
new iPhone la apple id login pannumbothu verification ketkathunga. device unga apple id ku register aagum. but 2 iPhones use pannureenga appadina old device ku 2 factor authentication message pogum. old phone active a iruntha mattum.
Mac laptop vachirukeenga na local system backup is best. icloud only if you dont have mac or storage problem in the mac bro.
new phone la esim transfer pannalaamnga. airtel la namma audience oruthar try pannirukaanga. suppose issue iruntha airtel or jio showroom visit pannitu eSIM new va register pannunga unga puthu iPhone ku.
Okay bro … i am having only one iphone 15 i am going to make ios restore because of battery issue…same phone laa thaan again antha backup eduka porean so finder or iCloud laa irunthu restore panrapa verification code varum nu solraanga so athuku epdi naa verification code aa paaka mudiyum when i am taking restore in same phone …or temporary aa mac laa my apple id a login panni vachikava illa phone number ku notification epdi varum bro
yes bro. both method are good to consider. if you have good internet connectivity then you may go with iCloud backup. otherwise finder backup and restore method will work. verification code varathunga when you are setting up new iPhone. also same sim card and apple id athe phone la thaan use pannureenga na no problem.
mac la already apple id login la thaana vachirukeenga?
Illa bro using different Id For macbook…same id from iphone odathu mac laa iruntha thaan finder laa backup and restore process panna mudiyuma illa different id irunthaalum pannalaam la bro ??
then it wont ask for 2 factor authentication when id is not logged in on one device bro. finder la ye pannalaamnga no problem. refer the video tutorial.
iPhone 15 is under warranty. if you have any doubt its better to visit nearest apple service center bro. they will do it for you.
Okay bro thanks for your help and time
