One plus Buds Z2 or Realme Buds Air 3 or Airpods 2nd Generation?
Which is best to buy in Flipkart billion sale?
My Budget will be below 10K and TWS with ANC Support needed
Suggest me with good TWS bro
Airpods goes well with apple ecosystem. If you are using iPhone, iPad or Mac, then airpods will be more convenient bro.
But if you are looking for alternatives and something that fits your budget, you may consider oneplus buds z2. do check user reviews and decide accordingly.
I’m using iPhone 13 bro for that One plus Buds Z2 will be fine or Can I wait for some day and get Airpods Pro 1st gen
AirPods has features like automatic pairing, easy switching between devices, and spatial audio that works with apple music and other content. It has its advantages, bro.
Oneplus buds will work as regular headphones, and they will fit well for budget reasons bro.
Bro I got an offer from apple Reseller for Apple Airpods 2nd Gen with Charging Case with 6 Months apple warranty for 7,500.
Is it worth to buy?
Afraid of buying in Flipkart bro that is why i have checked outside and they gave me this offer.
Whether it will be worth for that money in 2023.
Suggest me bro. Thanks for replies too bro❤️
Its always good to consider local shops and authorised showrooms bro. but why 6 months warranty? Is it open box unit or used for short duration?
I always recommend applying applecare+ to airpods, so that we can use it for 2 years and by the end of warranty period we can break it and get it replaced by paying 2500 service fee. to use the airpods for another 2+ years.
As we spend 10K or more to a headphone, using it atleast for 4 years will make more sense.
But at 7500 if you are ok to use it for next 2 years and consider changing to something available at that period of time, then yes its good deal.
Yes bro that’s a good thought from your end
It’s used one as customer used it for 6 Months and they gave to Apple reseller shop.
Bill Rate is 11,000 So they are giving for 7,500
ok bro. that pricing looks attractive. you can decide according to above scenario. now we cannot apply applecare+ as there is a limit of 90 days from the date of purchase. so decide based on that.
Thanks bro for your reply❤️
