Will eSIM Gets Deleted if I Restore my iPhone 11?
Hello Bro , Hope You are doing great ,im Having some doubts regarding the eSim because im going to use dual sims for my secondary sim which is jio.
I was using an iPad Cellular model with data only jio sim now im in idea of converting that number to eSim and configure it on my iPhone 11 before proceeding with this process
I have two major doubts regarding this
DOUBT 1: I perform occasional Backup and full restore of iOS through my mac if i do that will i lose my eSim and again i have to contact my carrier to assist?
DOUBT 2: If i buy new iPhone and how do i transfer the sim (by transferring manually through transfer methods or if I perform restore from my iphone 11 backup it will be automatically restored?)
I am good bro. thank you. hoping you too.
  1. eSIM have to be manually removed from settings - mobile or cellular data page. it wont be deleted even if we perform iOS Restore.
  2. eSIM Transfer feature is built inside migration tool. so when you bring two iPhones nearby and start the transfer process wirelessly it will ask for eSIM Transfer option. Jio and Airtel currently supports it. But if some server error occurred, we have to contact their support to resend QR Code to complete eSIM registration on new device.
Only in upcoming iOS 26 we will have a feature that allows us to transfer eSIMs without the need for migration assistant tool.
but for now we have to do it manually by contacting network support if anything goes wrong with eSIM transfer bro.
Bro hi , I have Converted my existing jio physical sim to eSIM and rendavadhu simah naan potrukken ennoda phone la
But one weird thing is happening idk what is it …
Airtel is primary Jio is Secondary
When i make call in either of them , the other sim is going to No service
Call mudinjadhukkapram everything is back to normal the tower is back on
Is this normal or is there any workaround bro
Hi bro, Dual SIM Dual Standby mode la thaan iPhone la work aagumnga. WiFi Calling ON la irunthu one sim connected a irunthuchuna Rendu SIM um active a irukumnga. otherwise oru sim GSM network la irunthalum automatic a no service pogumnga. call end aanathum again connect aagumnga bro. ithu normal thaan.
