Will Screen Protector cause issue to my Macbook Pro Display?
I went to a local store to Apply a screen protector for my MacBook Pro 14”. They said, The screen protector will cause some issues to the Display. Is that true? It’s not a glass one. It’s like a thin polythane.
applying thin film didnt affect my macbook air and my nephew macbook pro display so far bro. just to prevent the display directly touching the keyboard frequently which causes keyboard layout showing on display I have applied it and suggested the same in our video too.
if you use keyboard sleeve same time then it could be a problem. just screen protector thin type shouldnt be an issue. You can do bit more research via google search and decide bro.
Thank You for the Clarification Mr. Robin
can you please suggest me a cleaner for mac , in recent days my display get keys prints in my display but i am still scared is that cleaner gives any problem to the display . please let me know bro that you used already in the past that give you a great result
Hi bro, a friend of mine suggested this and so far good.
Spray it on cloth few drops and gently wipe the display. no need to press hard. to prevent oleophobic coating wear out over long term usage, I prefer very thin screen protector film like sheet applied on macbook display. then cleaning also easier and we just have to clean the screen protector every time if there are any smudge marks or fingerprints.
I hope it helps.
