Bro… i wont use apple music service. Instead I copied (sync) mp3 songs from mac to my iphone music app. Now i am planning to buy airpods pro2. Is spatial audio or dolby atmos works with downloaded music which sync from my mac?. Is it worth to buy ?.
hi bro, that wont work with spatial audio. only with streaming services that is compatible with spatial audio feature only will work. dolby atmos depending on the audio file you are copying may work bro. but spatial audio wont work.
you may take a spin of apple music trial and see whether the music collection you listen to are available and the audio quality is good or not bro. then you may decide to continue with subscription if trial went well.
