Hi bro, I am using iphone 14 promax and when using wireless (MagSafe) it gets very hot while charging. Could this cause battery health problem and phone accessories problem? But I use a 20 W Apple adapter and MagSafe is an original Apple product.
hello bro, if you are seeing temperature warning on the display, then its bad. you should stop using particular wireless charger. try different wireless charger and see same overheating happens.
Normally with wired or wireless charging we do see some temperature increase during fast charging. from 0 to 80%. that is normal.
But if the temperature is too much and seeing any warning message on the display then its not good.
As long as you use magsafe and original apple adapter with cable, you are good bro.
Once perform āSettings - general - reset - reset all settingsā on your iPhone and observe for 3 to 4 days how the heating increase overall.
Thanks bro
