Hi sir can you please suggest me an wireless will the magic mouse is best for editing
hello bro, apple magic mouse is the best that supports gestures in macOS and suitable for video or photo editing works. Are you looking for some budget apple magic mouse alternatives?
Budget is no problem sir whether shall i go with apple magic mouse or Logitech master 2s
In that case consider apple magic mouse bro. It works well with macOS using all the gestures available. over long term usage you will find it comfortable to use with from regular usage to editing too.
