Hey bro @iRobinPro Hope you’re doing good; i recently asked you Which mac is best under 1.5 lakh for developers?
is it worth buy Macbook pro 2017 15-inch in 2023 for software development?
I am good Praveen. Thank you. Hoping you too. It depends on which software you normally use for development. 2017 Macbook Pro 15 inch model is capable of running several programming apps and developers using it without much issues. It has good SSD Read and Write Speeds, and is suitable very well for beginners. But getting M1 series models is always wise choice in 2023 to use for another few years bro.
Intel Processor machines are capable, but if budget allows, you may consider M1 Macbook Pro models. Otherwise get 2017 Macbook Pro model.
I have one more question to ask, you are beginner into development or already working on certain platform?
@iRobinPro I have three years of experience in Python, two years of experience in web development, and I’m a student. You may know me from our Facebook group because I cloned your channel page with React and shared it there. I’m bad at choosing hardware, so only bro, so many confusions.
Apps and languages that I use on my computer:
Python
Javascript (bun; refer https://bun.sh for more)
GCC (GNU Compiler Collection)
VS Code (for web development)
Vim
The Apple Music app is not available in Windows, but I need an app like on the iPhone.
I remember the design work Praveen
Python developers are using both Intel and M1 machines. Is M1 Pro models fit your budget? Getting 512GB minimum storage will be good idea if you are planning for 13 inch Macbook Pro M1 processor model. As a basic thing, getting 16GB RAM also works well for multi tasking purposes.
@iRobinPro my budget is under 1.5 lakh or 1.3 lakh; ig macbook pro with m1 pro is ₹1,80,000 and above
If there is any possibility to get a student discount, you may consider this model bro 13-inch MacBook Pro - Space Grey - Apple (IN)
Macbook Pro 13" with 512GB SSD and 16GB RAM could come around 1.5 lacs budget range. ₹169900 is MRP for regular customers. HDFC card currently has 10K Cashback offer.
Macbook Air M2 Chip model with same specification costs same pricing. Under student offers you will see 10 to 15K discount too. If you need that slim profile and new display design, then Macbook Air M2 model can be considered too. Both are good choice.
